dara Nápodobne, mne sa zo špaldovej múky nikdy nič nepodarilo, takže už to neriskujem.
PEKNY DEN
...reagujem na vas prispevok,zhodou okolnosti som dnes robila chlieb zo SPALDOVEJ MUKY...A PODARIL SA NA MOJE PREKVAPENIE....
NAPISEM VAM RECEPT NA JEDEN BOCHNIK S POL KILA MUKY AKO SOM HO ROBILA JA A PODARIL SA...
1/2KG JEMNE MLETEJ CELOZRNEJ SPALDOVEJ MUKY
2LYZICE PSYLLIA
2LYZICE SLNEC.SEMIENOK
1LYZICA SEZAMOVYCH SEMIENOK
1LYZICA KMINU CELEHO/NEMUSI BYT TOLKO-PODLA CHUTI/
VODU-BUBLINKOVU/JA POUZIVAM Z LIDLU/
1SUCHE DROZDIE ZN.TESCO
POSTUP JE JEDNODUCHY-VSETKO ZMIESAT DO HROMADY MIESIT STACI 5-10MIN.POTOM NECHAT VYKYSNUT 1HOD. PO VYKYSNUTI UROBIT BOCHNIK A DAT HO DO NADOBY KDE BUDE DALSIU 1/2HOD.KYSNUT...PO VYKYSNUTI SA DA PIECT NA 1HOD.
PRVYCH 10MIN.SA PECIE NAPLNO,POTOM STIAHNUT RURU NA MINIMUM AK JE PLYNOVA A PIECT 50MIN.POCAS PECENIA KONTROLOVAT...AJ JE BLEDY TROCHU PRIDAT PLYN...
NIE JE TO NIC ZLOZITEHO...
ZELAM VAM ABY SA VAM CHLEBIK PODARIL,MNE SA PODARIL A JE VYBORNY
TEN ISTY DEN SOM ROBILA AJ PALACINKY Z TEJTO MUKY A TIEZ SU VYBORNE...KEDZE SOM ALERGICKA NA KAZEIN NAMIESTO MLIEKA DAVAM VSADE TUTO BUBLINKOVU VODU...Z LIDLU...
AK SA POKUSITE TENTO RECEPT VYSKUSAT BUDEM RADA AK TO POTOM DATE VEDIET CI SA AJ VAM PODARIL...
CHCEM SKUSAT AJ BUCHTY NA PARE ZO SPALDOVEJ MUKY...POTOM DAM VEDIET AKO TO DOPADLO...
ZELAM VAM PEKNY DEN
