system diagnose.. vyzera byt vsetko v poriadku. tiez na dalsiu vec ktoru som prisiel je, ze mam stiahnuty driver verz. 6.0 daco no po nainstalovani stale ukazuje verziu 5.0...
Advanced SystemCare Diagnose Report v1.0
Date: 2012.04.28 11:46:31
01 - Operating System
0101 - Operating System : Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.090804-1435)
0102 - Language : English (Regional Setting: Slovak)
0103 - BIOS : Ver 1.00PARTTBL
0104 - Processor : Genuine Intel(R) CPU T1600 @ 1.66GHz (2 CPUs)
0105 - Memory : 1976MB RAM
0107 - Page File : 1436MB used, 1815MB available
0108 - Windows Dir : C:\WINDOWS
0109 - DirectX Version : DirectX 9.0c (4.09.0000.0904)
0110 - DX Setup Parameters : Not found
0114 - DxDiag Version : 5.03.2600.5512
02 - Processor
0201 - Caption : Genuine Intel(R) CPU T1600 @ 1.66GHz x2 ~1662MHz
0202 - Current Clock Speed : 1662MHz
0203 - L1 Cache : 64,00 KB
0204 - L2 Cache : 1,00 MB
03 - Video Adapter
0301 - Card Name : Mobile Intel(R) 4 Series Express Chipset Family
0302 - Manufacturer : Intel Corporation
0303 - Chip Type : Mobile Intel(R) 4 Series Express Chipset Family
0304 - DAC Type : Internal
0305 - Device Key : Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_013C1025&REV_07
0306 - Display Memory : 256.0 MB
0307 - AdapterRAM : 256,00 MB
0308 - Current Mode : 1280 x 800 (32 bit) (60Hz)
0309 - Monitor Name : Plug and Play Monitor
0310 - Driver Name : igxprd32.dll
0311 - Driver Version : 6.14.0010.5225
0312 - Driver Language : English
0313 - DDI Version : 9 (or higher)
0315 - Driver Beta : False
0316 - Driver Debug : False
0317 - Driver Date : 1/26/2010 14:33:52
0318 - Driver Size : 57344
0319 - VDD : n/a
0320 - Mini VDD : igxpmp32.sys
0321 - Mini VDD Date : 1/26/2010 14:33:52
0322 - Mini VDD Size : 1914144
0323 - Device Identifier : {D7B78E66-6902-11CF-FC67-3621A6C2CB35}
0324 - Vendor ID : 0x8086
0325 - Device ID : 0x2A42
0326 - SubSys ID : 0x013C1025
0327 - Revision ID : 0x0007
0334 - DDraw Status : Enabled
0335 - D3D Status : Enabled
0336 - AGP Status : Not Available
0337 - Notes : No problems found.
To test DirectDraw functionality, click the "Test DirectDraw" button above.
To test Direct3D functionality, click the "Test Direct3D" button above.
0338 - OpenGL : 5.1.2600.5512 (xpsp.080413-0845)
04 - Memory
0401 - Total Memory : 1,93 GB
0402 - Free Memory : 1,12 GB
0403 - Total Pagefile : 3,18 GB
0404 - Free Pagefile : 1,77 GB
0405 - Bank Label : Bank 0
0406 - Speed : 667 MHz
0407 - Total Width : 64 Bits
0408 - Capacity : 1,00 GB
0405 - Bank Label : Bank 1
05 - Network
0501 - Description : Atheros AR928x Wireless Network Adapter - Packet Scheduler Miniport
06 - Motherboard
0601 - Model : Homa
0602 - Manufacturer : Acer
07 - Sound Device
0701 - Description : Realtek HD Audio output
0702 - Default Sound Playback : True
0703 - Default Voice Playback : True
0704 - Hardware ID : HDAUDIO\FUNC_01&VEN_10EC&DEV_0268&SUBSYS_1025013C& REV_1001
0705 - Manufacturer ID : 1
0706 - Product ID : 100
0707 - Type : WDM
0708 - Driver Name : RtkHDAud.sys
0709 - Driver Version : 5.10.0000.5911
0710 - Driver attributes : Final Retail
0711 - Date and Size : 8/5/2009 17:38:22
0713 - Driver Provider : Realtek Semiconductor Corp.
0714 - Min/Max Sample Rate : 4642746, 4642746
0715 - Static/Strm HW Mix Bufs : 4642746, 4642746
0716 - Static/Strm HW 3D Bufs : 4642746, 4642746
0717 - HW Memory : 4642754
0718 - Voice Management : False
0719 - EAX(tm) 2.0 Listen/Src : True, True
0720 - I3DL2(tm) Listen/Src : True, True
0721 - Notes : To test DirectSound functionality, click the "Test DirectSound" button above.
No problems found.
0701 - Description : Bluetooth Hands-free Audio
0702 - Default Sound Playback : False
0703 - Default Voice Playback : False
0707 - Type : WDM
0708 - Driver Name : btaudio.sys
0709 - Driver Version : 5.01.0000.3200
0711 - Date and Size : 3/23/2007 11:49:54
0719 - EAX(tm) 2.0 Listen/Src : False, False
0720 - I3DL2(tm) Listen/Src : False, False
No problems found.
08 - Hard Disk
0801 - Model : WDC WD1600BEVT-22ZCT0(Western Digital)
0802 - Media Type : Fixed hard disk media
0803 - Size : 149,05 GB
0804 - Interface Type : Serial ATA
0805 - Driver Date : 7-1-2001
0806 - Driver Version : 5.1.2535.0
0807 - Caption : C:\
0808 - Capacity : 54,25 GB
0809 - Free Space : 38,89 GB
0810 - Drive Type : 3-Fixed
0811 - File System : NTFS
0807 - Caption : D:\
0808 - Capacity : 94,79 GB
0809 - Free Space : 57,37 GB
09 - Process
0901 - 0000 Idle 0 0
0901 - 0004 System 0 0 normal
0901 - 023c smss.exe 0 0 normal C:\WINDOWS\system32
0901 - 0270 csrss.exe 58 60 normal C:\WINDOWS\system32
0901 - 028c winlogon.exe 40 11 high C:\WINDOWS\system32
0901 - 02b8 services.exe 4 0 normal C:\WINDOWS\system32
0901 - 02c4 lsass.exe 4 0 normal C:\WINDOWS\system32
0901 - 0368 svchost.exe 4 0 normal C:\WINDOWS\system32
0901 - 03ac svchost.exe 4 0 normal C:\WINDOWS\system32
0901 - 03d4 svchost.exe 11 11 normal C:\WINDOWS\System32
0901 - 03ec btwdins.exe 4 2 normal C:\Program Files\WIDCOMM\Bluetooth Software\bin
0901 - 0424 svchost.exe 4 0 normal C:\WINDOWS\system32
0901 - 0444 svchost.exe 4 0 normal C:\WINDOWS\system32
0901 - 0464 AvastSvc.exe 4 1 normal C:\Program Files\AVAST Software\Avast
0901 - 04f8 spoolsv.exe 4 0 normal C:\WINDOWS\system32
0901 - 0540 svchost.exe 4 0 normal C:\WINDOWS\system32
0901 - 056c stdrt.exe 250 48 normal C:\WINDOWS\TEMP\mrt26.tmp
0901 - 0678 Explorer.EXE 609 342 normal C:\WINDOWS
0901 - 079c egui.exe 200 52 normal C:\Program Files\ESET\ESET NOD32 Antivirus
0901 - 07b0 issch.exe 4 0 normal C:\Program Files\Common Files\InstallShield\UpdateService
0901 - 07c0 WTMKM.exe 55 84 normal C:\WINDOWS\system32
0901 - 07c8 SearchSettings.exe 22 13 normal C:\Program Files\Common Files\Spigot\Search Settings
0901 - 07e0 DivXUpdate.exe 48 19 normal C:\Program Files\DivX\DivX Update
0901 - 07ec avastUI.exe 69 18 normal C:\Program Files\AVAST Software\Avast
0901 - 0090 hkcmd.exe 9 13 normal C:\WINDOWS\system32
0901 - 00d8 igfxpers.exe 8 2 normal C:\WINDOWS\system32
0901 - 01a0 RTHDCPL.EXE 758 157 normal C:\WINDOWS
0901 - 025c ctfmon.exe 25 9 normal C:\WINDOWS\system32
0901 - 0824 RtkBtMnt.exe 11 6 normal C:\DOCUME~1\___\LOCALS~1\Temp
0901 - 0878 ApplicationUpdater.exe 4 0 normal C:\Program Files\Application Updater
0901 - 0890 mDNSResponder.exe 4 0 normal C:\Program Files\Bonjour
0901 - 08a8 ekrn.exe 8 3 normal C:\Program Files\ESET\ESET NOD32 Antivirus
0901 - 08f4 jqs.exe 4 0 idle C:\Program Files\Java\jre6\bin
0901 - 0934 o2flash.exe 4 0 normal C:\Program Files\O2Micro Flash Memory Card Driver
0901 - 09b0 svchost.exe 9 2 normal C:\WINDOWS\system32
0901 - 09ec atwtusb.exe 8 0 normal C:\WINDOWS\system32
0901 - 0c30 wscntfy.exe 17 6 normal C:\WINDOWS\system32
0901 - 0cf4 wmiapsrv.exe 4 0 normal C:\WINDOWS\system32\wbem
0901 - 0d68 alg.exe 4 0 normal C:\WINDOWS\System32
0901 - 02a8 atwtusb.exe 10 50 normal C:\WINDOWS\system32
0901 - 048c rundll32.exe 156 136 normal C:\WINDOWS\system32
0901 - 0c68 ASCService.exe 31 23 high C:\Program Files\IObit\Advanced SystemCare 5
0901 - 0b08 ASC.exe 2246 368 normal C:\Program Files\IObit\Advanced SystemCare 5
0901 - 1058 ASCTray.exe 98 41 normal C:\Program Files\IObit\Advanced SystemCare 5
0901 - 1288 ToolBox.exe 419 103 normal C:\Program Files\IObit\Advanced SystemCare 5
0901 - 04ac chrome.exe 88 36 normal C:\Documents and Settings\___\Local Settings\Application Data\Google\Chrome\Application
0901 - 05c4 chrome.exe 9 0 normal C:\Documents and Settings\___\Local Settings\Application Data\Google\Chrome\Application
0901 - 1660 chrome.exe 33 0 normal C:\Documents and Settings\___\Local Settings\Application Data\Google\Chrome\Application
0901 - 1394 wmiprvse.exe 7 4 normal C:\WINDOWS\system32\wbem
0901 - 15e8 Sus10_SysExplorer.exe 103 42 normal C:\Program Files\IObit\Advanced SystemCare 5
10 - Service
1001 - Application Layer Gateway Service - [C:\WINDOWS\System32\alg.exe]
1001 - Application Updater - ["C:\Program Files\Application Updater\ApplicationUpdater.exe"]
1001 - Windows Audio - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - avast! Antivirus - ["C:\Program Files\AVAST Software\Avast\AvastSvc.exe"]
1001 - Background Intelligent Transfer Service - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - ##Id_String1.6844F930_1628_4223_B5CC_5BB94B879762# # - ["C:\Program Files\Bonjour\mDNSResponder.exe"]
1001 - Bluetooth Service - [C:\Program Files\WIDCOMM\Bluetooth Software\bin\btwdins.exe]
1001 - CryptSvc - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - DCOM Server Process Launcher - [C:\WINDOWS\system32\svchost -k DcomLaunch]
1001 - DHCP Client - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - Logical Disk Manager - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - DNS Client - [C:\WINDOWS\system32\svchost.exe -k NetworkService]
1001 - ESET Service - ["C:\Program Files\ESET\ESET NOD32 Antivirus\ekrn.exe"]
1001 - Error Reporting Service - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - Event Log - [C:\WINDOWS\system32\services.exe]
1001 - COM+ Event System - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - Fast User Switching Compatibility - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - Help and Support - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - HID Input Service - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - Java Quick Starter - ["C:\Program Files\Java\jre6\bin\jqs.exe" -service -config "C:\Program Files\Java\jre6\lib\deploy\jqs\jqs.conf"]
1001 - Server - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - Workstation - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - TCP/IP NetBIOS Helper - [C:\WINDOWS\system32\svchost.exe -k LocalService]
1001 - Network Connections - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - Network Location Awareness (NLA) - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - O2Micro Flash Memory Card Service - ["C:\Program Files\O2Micro Flash Memory Card Driver\o2flash.exe"]
1001 - Plug and Play - [C:\WINDOWS\system32\services.exe]
1001 - IPSEC Services - [C:\WINDOWS\system32\lsass.exe]
1001 - Protected Storage - [C:\WINDOWS\system32\lsass.exe]
1001 - Remote Access Connection Manager - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - Remote Registry - [C:\WINDOWS\system32\svchost.exe -k LocalService]
1001 - Remote Procedure Call (RPC) - [C:\WINDOWS\system32\svchost -k rpcss]
1001 - Security Accounts Manager - [C:\WINDOWS\system32\lsass.exe]
1001 - Task Scheduler - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - Secondary Logon - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - System Event Notification - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - Windows Firewall/Internet Connection Sharing (ICS) - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - Shell Hardware Detection - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - Print Spooler - [C:\WINDOWS\system32\spoolsv.exe]
1001 - System Restore Service - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - SSDP Discovery Service - [C:\WINDOWS\system32\svchost.exe -k LocalService]
1001 - Windows Image Acquisition (WIA) - [C:\WINDOWS\system32\svchost.exe -k imgsvc]
1001 - Telephony - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - Terminal Services - [C:\WINDOWS\System32\svchost -k DComLaunch]
1001 - Themes - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - Distributed Link Tracking Client - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - Windows Time - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - WebClient - [C:\WINDOWS\system32\svchost.exe -k LocalService]
1001 - Windows Management Instrumentation - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - WMI Performance Adapter - [C:\WINDOWS\system32\wbem\wmiapsrv.exe]
1001 - Security Center - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - WTService - [C:\WINDOWS\system32\atwtusb.exe -s]
1001 - Automatic Updates - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - Wireless Zero Configuration - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - Advanced SystemCare Service 5 - [C:\Program Files\IObit\Advanced SystemCare 5\ASCService.exe]
12 - Event Log
1201 - Time : 27.4.2012 21:30:42
1202 - Source : PerfNet
1203 - Description : Unable to read Server Queue performance data from the Server service. No Server Queue performance data will be returned in this sample. Error code returned is in data DWORD 0, IOSB.Status is DWORD 1 and the IOSB.Information is DWORD 2.
1203 - Description : Unable to read performance data from the Server service. No Server performance data will be returned in this sample. Error code returned is in data DWORD 0, IOSB.Status is DWORD 1 and the IOSB.Information is DWORD 2.
1201 - Time : 27.4.2012 21:28:00
1201 - Time : 27.4.2012 21:26:13
1201 - Time : 27.4.2012 21:15:18
1201 - Time : 27.4.2012 20:56:06
1202 - Source : Google Update
1203 - Description : N/A
1201 - Time : 26.4.2012 14:05:15
1202 - Source : Application Error
1203 - Description : Faulting application stdrt.exe, version 5.2.0.0, faulting module unknown, version 0.0.0.0, fault address 0x003a0f35.
1201 - Time : 28.4.2012 5:26:58
1202 - Source : Service Control Manager
1203 - Description : The Adobe Licensing Console service failed to start due to the following error: The service did not respond to the start or control request in a timely fashion.
1203 - Description : Timeout (30000 milliseconds) waiting for the Adobe Licensing Console service to connect.
1201 - Time : 27.4.2012 23:14:42
1201 - Time : 27.4.2012 22:59:07
1201 - Time : 27.4.2012 22:36:33
1201 - Time : 27.4.2012 22:27:41
End of file - 21903 Bytes
