neviem.ako
Takze posielam tu ten kod, co tam vybehuje, vraj sa podla toho da zistit, kde je chyba. DRIVER_IRQL_NOT_LESS_OR_EQUAL
STOP:0x000000D1 (0x00000004, 0x00000002, 0x00000001, 0x83864340)
Ram som nemenila, lebo ani neviem, co to je
na cistenie registrov pouzivam Ccleaner. Verim, ze tu niekto pomoze. Dakujem
tu by si mala najst odpoved
http://support.microsoft.com/default...b;en-us;810093
skratene bud je vadna RAMKA .. nemusi byt nutne cela len jedna cast z nej a ked sa z nej pokusa citat tak to padne alebo treba upravit virtual memory
Postup:
1 Click Start, right-click My Computer, and then click Properties.
2 Click the Advanced tab.
3 Under Performance, click Settings.
4 Click the Advanced tab.
5 Under Virtual Memory, click Change.
6 Click No paging file. Click OK, click OK, and then click OK.
7 Restart your computer.
8 Click Start, right-click My Computer, and then click Properties.
9 Click the Advanced tab.
10 Under Performance, click Settings.
11 Click the Advanced tab.
12 Under Virtual Memory, click Change.
13 Click System managed sized. Click OK, click OK, and then click OK.
14 Restart your computer.
